#1 What's this toe box hole for?!?
Posted: Sun Jan 27, 2013 2:21 pm
by chrisvine
Please can someone tell me what goes through the small hole (7/32") in the LHS/passenger toe box, the lower one in the photo below:
It's too small for any grommets supplied in the Autosparks set. I'm just about to install Koolmat and so access to this hole will be difficult once it's all bonded in place.
Thanks,
Chris
Posted: Sun Jan 27, 2013 2:25 pm
by ChrisC
Bit of a long shot as I am not sure where series 2 pipes run... but if the hole is threaded - perhaps its for a brake pipe retaining clip?
Posted: Sun Jan 27, 2013 2:33 pm
by chrisvine
Thanks Chris.
It's not threaded so I'm assuming I'll need to have access to it from inside the footwell.
The brake pipe fitting is on the other side of the servo unit and the hydraulic switch for brake lights screws into the fitting.
I guess it could be for the wires to the switch but I'd have expected it would then have a grommet. I'll look at the wiring looms to see where this wire comes out.
#4 Small Hole
Posted: Sun Jan 27, 2013 4:10 pm
by vacbag
Chris.
I have just looked at mine and i just have an empty hole. I then looked at the original pictures i took before i rebuilt the car and the hole was filled with a rubber plug.
Steve.
Posted: Sun Jan 27, 2013 4:26 pm
by harryetype
Its a threaded hole to take the bolt that secures the Earth cable from the Battery plus other Earth cables that run from the loom.
Posted: Sun Jan 27, 2013 4:44 pm
by 1954Etype
Harry, its the smaller hole not the earth mounting.......
Posted: Sun Jan 27, 2013 6:30 pm
by chrisvine
Thanks all for the replies - I'll blank it off.
#8 Re: What's this toe box hole for?!?
Posted: Sun Jan 27, 2013 6:38 pm
by PeterCrespin
chrisvine wrote:Please can someone tell me what goes through the small hole (7/32") in the LHS/passenger toe box, the lower one in the photo below:
Thanks,
Chris
Probably something to do with the carbon cannister and hoses in that area on US S2 cars. A P-clip hole perhaps for the tank breather line? Not sure.
Posted: Sun Jan 27, 2013 9:08 pm
by harryetype
Well spotted I wanted to make sure that you're paying attention. My eyes were drawn to the obvious.
#10
Posted: Sun Jan 27, 2013 9:14 pm
by 1954Etype
:D So were mine initially so I read it again. Glad I passed the test though!
#11
Posted: Sun Jan 27, 2013 10:01 pm
by chrisvine
Thanks - I had read about a fuel breather for the US cars but being RHD I didn't pay much attention so the P-clip must be why it's there.
At least Harry's response saves me the trouble of asking another daft question when I get round to installing all the engine bay components.
The car was dismantled prior to digital cameras becoming widely available so I?ve only got a handful of vaguely useful ones to go on and what I can remember!
