4.2 Timing
glennglenn
#1 4.2 Timing
Post by glennglenn » Fri Jul 18, 2008 6:52 pm
I have just fitted electronic ignition to my e type, after fitting they recommend that the timing is checked, the timimg marks are underneath.
Can anyone tell me how to use a timing light (under the car) and adjust the distributor without removing the bonnett?!!!!
andyp
Post by andyp » Sat Jul 19, 2008 1:04 am
Glenn
Just make yourself another timing mark on the top.
There is usually a bolt around somewhere near that you can use to hold a pointer (one cut from tinplate or bent from a length of piano wire will do).
Line up the timing mark underneath, get your new pointer in line with the pulley at the top and then mark the pulley with a dab of white paint.
If you want something more permanent make a nice stiff pointer and file a goove at your new timing mark.
I bet you are now wondering how on earth you didn't think of that yourself now.
Have fun
Andy
1966 2+2 MOD Conversion
jmgtaylor
#3 timin
Post by jmgtaylor » Wed Oct 08, 2008 8:39 pm
I read somewhere recently about someone bolting another timing mark on and pulley from an XJ6 which was timed from the top on the near side somewhere - might have been in the practical classics etype restoration book if not mistaken
