#1 intermittent rev counter/horn fail
Posted: Tue Aug 27, 2013 9:47 am
by Kes
Can anyone throw any light on this problem? Occasionally (although becoming more frequent lately) the rev counter will drop back to zero whilst I'm driving. It seems that at the same time the horn stops working. Both usually start working again after a few minutes....
Any idea where I might start looking for the problem?
Thanks,
Kes
Posted: Tue Aug 27, 2013 5:42 pm
Sounds like a bad earth. The Electronic tacho on an S2 usually needs the case to be earthed as the readout ( but not the sensing which depends on the inductance from the white loop wire ) depends on the tacho having a viable 12 volt supply via its green wire and a satisfactory earthing of the case. The horn also is requires a good earth to work properly and if the two are ceasing to work simultaneously it is likely that some common earth is being interrupted
#3 Re: intermittent rev counter/horn fail
Posted: Fri Jun 30, 2017 5:40 pm
by Keith in Norfolk
Check the fuse holder as well as the fuse , mine had melted making it a bad connection and causing the same
faults you have described.
#4 Re: intermittent rev counter/horn fail
Posted: Fri Jun 30, 2017 8:16 pm
Come on Keith keep up ...he asked the question 4 years ago :bigrin:
#5 Re: intermittent rev counter/horn fail
Posted: Sat Jul 01, 2017 7:51 am
by 288gto
In fairness Steve, he never came back on to say thanks I've fixed it. He might still be stuck crying in his garage after four years surrounded by a dissassembled E type that started off as a simple electrical fault. :lol: :lol:
#6 Re: intermittent rev counter/horn fail
Posted: Sat Jul 01, 2017 3:28 pm
by mark10337
like the rest of us you mean? :bigrin: Come on Simon, it's time for an update on your rebuild...
