#1 oil on flywheel
Posted: Sat Mar 22, 2014 6:24 pm
I would appreciate any comments or recommendations.
I have had a gearbox oil leak from the front bellhousing seal. It leaked on the pressure plate, friction plate and flywheel surface.
After cleaning the flywheel surface with brake cleaner, there remains a number of black areas on the flywheel that I would like to remove. I believe either they are burnt oil residue or areas of the flywheel that were heated more than other areas. The clutch was slipping horribly before removing.
I would like to use 400 Grit sand paper and gently sand the flywheel surface then clean again with brake cleaner, is this wise? Or should I get the flywheel resurfaced?
Any suggestions?
Any suggestions?
