here are a few cleare pics with :
. one set of wires being black and black/red
. the other one being black and black/green
the loose single cable is beige/black
the fans feeding has been fiddled, now only one single cable and they run permanently; if I switch the cable to the thermostat: same, permanent running whatever the T?
I understand from Manual that in my case of a 2+2 with Aircon, there should be 2 relays, one overriding when Aircon is turned on
I looked for a couple of relays but only could find 3 close to the battery; wrong ones ?
