#1 centre console chrome surround
Posted: Sat Apr 05, 2014 8:13 pm
by thexkeprocess
has any one tried to replace the chrome strip surround that goes around the gear shift leather boot hole.
the original version is unavailable, what you get is a straight strip of plastic that you are suppose to shape using something like a hair dryer to heat it up slightly and shape it to fit.
I have tried twice with mixed results.
Is there a trick, has anyone else done it with good results?
Comments please
Posted: Sun Apr 06, 2014 1:01 pm
by johnney
Hi Mark,
when bought as a spare part originally they were supplied as a straight piece by the factory, so will need heating to fit. Hot water is probably the safest way to heat them up prior to fitting.
Posted: Sun Apr 06, 2014 1:12 pm
And use a small rubber or wood mallet to tap it into place. Start with the join at the front and work around the full 360 degrees and then cut it to length for a tidy fit.
#4 chrome gear box shift surround
Posted: Mon Apr 07, 2014 12:39 am
by thexkeprocess
I guess I will have to try again, the problem seems to me that its an art to getting it to look right. I'm just not that artistic!
Thanks for all the comments
Posted: Mon Apr 07, 2014 5:59 am
by PeterCrespin
I've got a NOS spare bagged as a shaped part, not straight. You have to use the correct thin vinyl on the cover because the chrome trim struggles if modern thicker elasticated vinyl is used. Same goes for the larger FHC hinge cover trims and the sill chromes on all models.
Posted: Mon Apr 07, 2014 2:55 pm
by johnney
PeterCrespin wrote:I've got a NOS spare bagged as a shaped part, not straight.
Would you be interested in selling it Peter?
Posted: Tue Apr 08, 2014 1:10 pm
by PeterCrespin
No thanks :-)
Posted: Mon Apr 28, 2014 8:16 pm
by Bob Falfa
I used a very hot hairdryer to bend the length of chrome trim to suit. This worked very well, and also enabled the apature to be opened up slightly, by gently prising it apart with a flat bladed screwdriver. Finally, a squirt of washing up liquid helped to ease the chome over the vinyl.
