#1 engine oil spec '69 4.2
Posted: Thu Aug 28, 2014 5:05 pm
by Henkie
Is it correct that a '69 4.2 needs 20W50 engine oil?
Thanks for your response.
Posted: Fri Aug 29, 2014 7:55 am
by christopher storey
Certainly 20/50 gives the best results . I have in the past used 15/40 which is easier to get, but it is a little on the light side when hot and results in rather higher oil consumption
Posted: Fri Aug 29, 2014 8:44 am
by Simon P
'Tis what I use in my 1969 4.2 - and is what was recommended by my engine builder.
Millers do it, but it's also freely available as Halfords Classic:
20 quid for 5 litres, or 30 quid for 10!
Posted: Fri Aug 29, 2014 9:29 am
by iani
I used Halfords Classic in my Stag, following advice I changed to Valvoline VR1 and saw a 5psi improvement in oil pressure across the temperature range, I now use VR1 in my S2.
Ian
Posted: Fri Aug 29, 2014 11:09 am
by PeterCrespin
Pressure isn't the be-all and end-all criterion - flow is important. Since most wear occurs on startup and all oils are orders of magnitude thinner at running temp than even a 5W-30 is cold, one can argue that it makes more sense to use a modern thin oil and avoid the wear.
Posted: Fri Aug 29, 2014 11:17 am
I'm sorry, Peter, I cannot agree. Modern oils are for modern engines whose running clearances are radically smaller than engines designed 70 years ago. If you run thin oils in an XK, two things happen: 1. the oil film on the bearings , which actually provides the prevention of metal to metal contact, is negligible , and 2. the oil consumption increases significantly . I have never in fact tried the straight 30 which was the recommended lubricant when the XK was designed , ( and which we always used in my father's Jaguars in the 1950s ), but I suspect the results would not be very different from using 20/50 .
Posted: Fri Aug 29, 2014 6:28 pm
by Henkie
Thanks guys. I'm going to use 20W40!
How many liters wil go in the engine? Is it 7?
Posted: Fri Aug 29, 2014 7:24 pm
by PeterCrespin
Until pretty recently Chris I would have agreed with pretty much every word except the thin film bit. Recently I have read around the subject and have a different view now compared to that I've held for the last 40 years.
Chacun a son gout...
#9
Posted: Fri Aug 29, 2014 9:42 pm
I didn't know you had gout along with your other troubles , P
#10
Posted: Fri Aug 29, 2014 9:44 pm
Henkie : the correct quantity on a refill including filter is 14.5 pints ( 8.25 litres ) . Do not rely on the dipstick until you have filled the sump precisely, which will tell you whether the dipstick calibration is correct
I should perhaps say that the book says 15 pints ( 8.5 litres ) but the modern pundits such as David Marks all say 14.5 pints
#11
Posted: Tue Dec 23, 2014 7:37 am
by Henkie
christopher storey wrote:Henkie : the correct quantity on a refill including filter is 14.5 pints ( 8.25 litres ) . Do not rely on the dipstick until you have filled the sump precisely, which will tell you whether the dipstick calibration is correct. I should perhaps say that the book says 15 pints ( 8.5 litres ) but the modern pundits such as David Marks all say 14.5 pints
Reading your message for the second time..... you mentioned 8,5 liters and do NOT rely on the dipstick! What do you mean with that?
I had to fill up my engine with 10 liters before the dipstick reads full
#12
Posted: Tue Dec 23, 2014 9:18 am
The problem with the dipstick is threefold
1. People substitute non E type dipsticks which read incorrectly
2. On some dipsticks a collar is used which can slip , thus giving an incorrect datum for the dipstick to work from
3. Much the most common problem is that the dipstick gets bent by impact against the horizontal tray in the sump, and then reads grossly incorrectly
This is why you should check your initial level by filling the sump with 14.5 imperial pints /8.25 litres and then check your dipstick calibration against that
I should emphasise that these figures relate to 6 cylinder engines
#13
Posted: Thu Dec 25, 2014 7:33 am
by Henkie
oke, thanks Christopher
#14 Re: engine oil spec '69 4.2
Posted: Wed May 23, 2018 2:04 am
by JJC
5W30Wt in my 73 V12 for over 30 years. Works great, no leaks. Trick with engine oil is simply buy cheapest you can find, like Walmart in the United States, but change oil and filter often. I have a spin on filter, which I change every 1000 miles (easy..5 minutes) , and change oil every 3000 miles. Its a good practice to send oil samples out once in a while for analysis. Good to know whats going on inside the engine. Habit I picked up as an aircraft owner. Usually around 20 bucks US.
Happy motoring !
JC
#15 Re: engine oil spec '69 4.2
Posted: Wed May 23, 2018 12:33 pm
by Moeregaard
I've always used Castrol 20/50 in all of my old British iron. I stay away from the synthetics and the low-viscosity stuff because they have an annoying tendency to work their way out of the engine and onto the garage floor. What's just as important is to change the oil frequently, especially if the car is used for short trips. On the E-Types, I just followed the factory's recommended change intervals.
#16 Re: engine oil spec '69 4.2
Posted: Wed May 23, 2018 3:26 pm
by Series1 Stu
JJC wrote: ↑Wed May 23, 2018 2:04 am
JC
I see no benefit in changing the oil filter every 1000 miles but don't let that stop you, there's certainly no harm in it. However, I would recommend changing the oil every 3000 miles or annually, depending on which comes around soonest. Change oil and filter at the same time.
Regular oil analysis is a good idea.
Choice of oil is subjective and depends on the condition of the engine and the way it is used but a good 20/50 is probably best for our engines.
#17 Re: engine oil spec '69 4.2
Posted: Wed May 23, 2018 8:39 pm
by JJC
The reason I change filters at 1000 miles is two fold. #1 All filters are built with a bypass valve that sends oil back to the engine after a relatively short period of time, so the filter is doing nothing. As the filter has no monitor, my experience is that they are useless after 1600 to 1800 miles. So, and now reason #2, the spin on filters are only $4.00, so why not spin one off, and spin a fresh one on every 1000 miles or so. Since my oil maintenance is based on 1000 mile intervals, its easy to keep track. Another cheap way to keep your engine internals happy ! My test results indicate that my engine is a very content baby, with only slight, below normal wear. Happy Motoring !
1973 E-Type V-12.
Owned since new.
150000 New York City miles.
#18 Re: engine oil spec '69 4.2
Posted: Thu May 24, 2018 10:34 pm
by SESH
Always use 20W50 Valvoline VR1 Racing oil. As recommended to me by JD Classics.
