#1 radiator fans regulation on aircon + power steering models
Posted: Sat May 16, 2015 10:03 am
by rolando38
on my 2+2 1970 Aircon and power sterring where very common if not standard on US models
thePO suppressed the PAS, and the Aircon does not seem to be operational either
with these 2 options, Jaguar had decided to suppress the thermostat and have both fans permanently on
this doesn't make any more sense now since the stress of both accessories on the engine is now removed, and I'm not sure either it was a good choice for non-californian climates:
. noisy
. pulls on battery
. refreshes the engine even when cold
the wire was even disconnected by previous PO, and I only realized when I saw steam coming from the rad when engine was at idle speed for a long time...!
my question is therefore, what should I do ?
. put a new thermostat as on non-optioned cars ?
. pull 2 wires to the dash to a free switch to operate manually when hot (it can be over 35?C in summer in the Alps...and I do plan to take her to a few passes)
in this case what relay should I fit and where
. both
. other
thanks for your advice
Posted: Sun May 17, 2015 10:14 am
by 42south
Personally I would fit the switch from coolcatcorp.com , they are excellent quality. Then all you need is a modern solid state automotive relay, which any autoelectrican could supply. This would modernise the system to a more reliable setup.
On my S3 I also did pull wires to a spare switch on the dash panel. This does give some peace of mind on a hot day in traffic. If its hot, and I have to stop in traffic, I turn mine on immediately, before the thermostat reaches its temperature.
cheers
Posted: Sun May 17, 2015 1:47 pm
by rolando38
Thanks 42South
I guess you have this one in mind ?
agree, only one drawback is that I will run the risk that my now watertight water circuits gets leaky
Posted: Mon May 18, 2015 12:56 am
by 42south
Yes that's the switch.
As far as leaks go, there is no reason at all for a leak. I think you will find the switch will come with a gasket, which could be fitted dry as I did with mine, or with a smear of sealant.
My S3 has never leaked a drop in 5 years, with a similar coolcat switch fitted.
Posted: Mon May 18, 2015 12:33 pm
by rolando38
sounds great, I'll grab one !
