#1 Centre switch panel
Posted: Mon Jul 20, 2015 8:11 pm
by Gfhug
The centre switch panel has never hinged down far being restricted by the radio console, especially the guards around the headlight switches pushing against the top of the radio console. Maybe an angle of 45 degrees, but with the radio console removed it hinges about 90 degrees.
Had hoped that when refitting the gearbox cover and central armrest that it would fit lower and give decent access to the fuses and switches. Not so.
What is normal? Any advice to improve the situation?
Thanks, Geoff
Posted: Tue Jul 21, 2015 10:21 am
Hi Geoff....have the same problem, never got around to fixing it....searched jagloveres and found this.....may help Steve.
http://forums.jag-lovers.org/av.php?1568895n13
Posted: Tue Jul 21, 2015 4:05 pm
by Riv944
Hi Geoff
have the same problem, I think on mine cos there is a lot of sound/heat insulation around the area. I leave my radio console loose, it doesn't move at all and if I need to drop down the console I just pull it forward. There is enough wire on the radio to make it easily.
Ian
Posted: Tue Jul 21, 2015 6:28 pm
by Gfhug
Thanks Steve and Ian. Had a look at Jag Lovers and the suggestions.
The metal cover over the gearbox is as low as the fixings will allow, so may have to trim the carpet where it fits under the centre armrest and see if that'll do the job. Or accept pulling out the radio panel to gain access.
Posted: Wed Jul 22, 2015 2:43 am
If I can be bothered I'm going to try trimming 1/2" off the BOTTOM of the console. This should let it sit a bit lower.
If you end up with an unsightly gap between the top of the console and the bottom of the panel you can then fit the rubber strip.
