Rear Suspension camber angle shims
JOHN HAY
#1 Rear Suspension camber angle shims
Post by JOHN HAY » Sat Aug 01, 2015 4:23 pm
Does any one know how to determine how many shims are required for the rear caster angle
Post by mgcjag » Sat Aug 01, 2015 5:25 pm
Hi John...your post heading was for camber your question for castor.....see manual section K15 for how to set camber angle....no rear setting for castor.....camber one shim 0.020in alters camber by approx 1/4 deg.... Steve
JOHN HAY
Post by JOHN HAY » Sat Aug 01, 2015 6:15 pm
Thanks, for the reply, yes should have been camber
