#1 New speedo right angle drive/cable lasted < 1mile!
Posted: Sat Aug 01, 2015 6:56 pm
I fitted a new speedo cable (complete inner and outer) and right angle drive but the new combo has lasted less than a mile
What could I have done wrong?
I removed the centre console etc to fit the new cable and drive from above. While in there there I fitted a new foam noise/heat insulation pad. The old cable and drive came out easy enough and revealed that the gearbox end of the drive had snapped off. The new drive didn't seem to locate very positively but I was able to tighten it up and all seemed well. Routed the new cable as per the old one and put everything back together.
It was a P.I.T.A job, especially squeezing the new unformed pad back under the gearbox cover, and I'm not looking forward to doing the whole thing over again
The car is a '69 LHD S2 FHC and the new cable and drive were supplied by SNG Barratt.
