#1 LHD Throttle linkage
Posted: Tue Sep 01, 2015 5:24 pm
This is my first post and I'm hoping some of the more learned forum members can help?
I have recently imported a 1969 LHD S2 OTS in Primrose yellow from California. Having previously owned a 1969 RHD S2 FHC up until 2003.
I took it out for a test drive to give it a good shake down after its long sea voyage, and it was more exhilarating than I planned because the throttle stuck on! Having worked back from the carbs I tracked the problem down to where the throttle linkage passes through the bulkhead and pivots around a large (9/16" I think?) bushed nyloc nut and bolt.
Having removed the bolt and the arm that connects to the throttle linkage that runs along the bulkhead, there was a dull thud in the footwell. Which revealed that the linkage connected to the pedal and a U shaped wire spring. I have a picture but I'm not sure how to post it??
I believe the set up for LHD throttle pedals is different to RHD?
The million dollar question is how does it fit back together...and are there any top tips as space is limited? A picture would be great.
