lower ball pin cap issue
rolando38
#1 lower ball pin cap issue
Post by rolando38 » Sun Sep 13, 2015 7:35 am
hello
I've been replacing the ball pins of mys series 2, not because they were used , but because they had no more bellows left
the left lower ball pin cap was as expected, with a removable plastic "cup" which relacement is provided in the Barratt kit I purchased
But when the right hand one came off, I was surprised to see that the "cup" was not only in a different material (blackish glassfiber...?) but impossible to remove from the metal part
and when trying to remove it I damaged it even more
any clue how to remove it ?
If I need to change the whole subassembly, the metal part is not available at Barratt, any place where I can find one (preferably in Europe) ?
thanks
2+2 1970
Post by abowie » Sun Sep 13, 2015 8:17 am
Remove them and throw them in the bin.
Replace them with sealed for life units.
http://www.sngbarratt.com/ProductDetail ... 63077467be
nefematic
Post by nefematic » Sun Sep 13, 2015 9:54 am
Andrew,
thanks for the link. It specifies S1 and S3, Rolando's car (and mine too) is S2. Would this still be the right one to get? My gaitors are missing, There is no play that I can see, but I want to get mine fixed and need to order a pair.
Thanks,
Martin
Martin Scherz
Late S2 1970 OTS US LHD
David Oslo
Norway
#4
Post by David Oslo » Sun Sep 13, 2015 12:23 pm
You can just order the gaitors if you deem the balljoints themselves to be fine. I did this on my lower ball joints and on the track rod ends. Original gaitors had perished / dried up in storage.
David
S2 OTS '70 (arriving)
rolando38
Post by rolando38 » Sun Sep 13, 2015 4:59 pm
hum, having already mounted the RH one, not so keen of dismantling it again
and as Martin mentions, they do not seem to fit the S2
2+2 1970
RogerM
Post by RogerM » Sun Sep 13, 2015 6:54 pm
They do fit the Series 2. I have just fitted a pair to mine - goodbye shims.
There are several errors of this type in the Barratt catalogue / website. If in doubt give them a ring; I found them very helpful.
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
rolando38
Post by rolando38 » Sun Sep 13, 2015 7:37 pm
thanks Roger
might use this solution if I can't save the one on pic above; would save me a dismantling on other side
2+2 1970
Post by 1954Etype » Sun Sep 13, 2015 8:09 pm
No point using the original, shimmed joint in my view.
Post by abowie » Sun Sep 13, 2015 10:48 pm
They fit everything and are a much better design.
You might need slightly shorter bolts, although I haven't had a problem on my cars.
Quattrofrank
Norway
#10
Post by Quattrofrank » Mon Sep 14, 2015 7:05 am
Can confirm that the sealed for life balljoints fits series 2.
Post by 1954Etype » Mon Sep 14, 2015 7:06 am
Definately.
