#1 Help me understand headlight operation
Posted: Sat Dec 05, 2015 12:52 am
I will preface my questions with two points in my defense:
1. My car is TOTALLY apart, and has been so since I got it. I have no prior frame of reference vis-a-vis a "complete" car.
2. I think part of my misunderstanding on this topic is due to different terms and idioms in American-British languages. SO....
I think these terms correlate. Correct me if I'm wrong:
> main beams = high beams or bright lights
> dipped beams = low beams or dimmed lights
> dipper switch. Switches on the high (main) beams, and at the same time switches off the low (dipped) beams, and vice versa. It is NOT a momentary function. This is the switch in the green circle in my picture. This switch is mounted WHERE?
> headlamp flash switch. Flashes the bright lights while the low beams are on, as a signal. This IS a momentary function. I think this switch is activated by pulling the turn signal lever toward me and releasing. This is the switch in the blue circle in my picture.
I think once I understand the terms and the physical locations of these items it'll be clearer.
My turn signal stalk does not have a push-for-high/pull-for-low positions as do many cars; only the "flash' (pull) portion. Where is this switch? (See my bold type question above).
Could someone kindly step me through where these these switches are and how they work?
Thanks for your patience!
