Steering wheel restoration
rolando38
#1 Steering wheel restoration
Post by rolando38 » Sun Jan 10, 2016 6:13 pm
Hello
Today I decided to tackle the restoration of my 16" S2 steering wheel, original but looking a bit sorry:
front surface badly used:
usual cracks above the 2 horizontal branches , making the top half of the wheel too "flexible"
I could have simply replaced it by a new one but I don't like the idea of parting the car with its original parts and second I was interested in the remanufacturing, so I purchased 2 halves of mahogany from a reputed UK craftsman
the interior of one one the halves is grooved
the opening is slightly too small, will need soe adjustment
some of the bits come easily , but generally the wood has been very well
with the use of a chisel, I snapped off wood chips
I also used a plane to remove the thicker wood parts left; needs some re-sharpening but as the metal is aluminium, still a soft material
and that's what left of it on one side...
and on the other side...
insertion into the grooved half
and the second
the "holes " for the fingers (round) are slightly different from original (oval)
next step is to glue the parts together; I wil probably 1st glue the grooved half to the aluminium and the the second wooden half
haveto find the right glue, though
any previous tests ?
2+2 1970
Post by abowie » Sun Jan 10, 2016 7:35 pm
I use Araldite (epoxy) and glue both halves on at the same time.
You will need to clamp the 2 halves together.
rolando38
Post by rolando38 » Mon Jan 11, 2016 6:09 am
thanks !
I ordered the same epoxy resin used by Chris
not so easy to find in France, though
2+2 1970
rolando38
Post by rolando38 » Mon Jan 18, 2016 8:00 pm
Restoration of the wheel part 2
don't forget to mask the aluminium parts close to the wood
and prepare alcohol for cleaning of the resin in excess
there cannot be exactly the exact amount of resin , and if there isn't enough there will be holes or worse ; therefoe you need to have excess
you also need to align transversally the 2 halves
tomorrow I will release the clamps and try to "turn" the whel on a drill (as if it was a lathe) with a central wooden shaft
2+2 1970
rolando38
Post by rolando38 » Wed Jan 20, 2016 4:58 pm
after removal of the G clamps
more extr resin than expected
after 45 minutes of grinding wiith Dremmel
still some more sanding needed...
2+2 1970
andrewh
Post by andrewh » Wed Jan 20, 2016 5:47 pm
very interesting. you prompted me to do the same with my spare wheel but its going to be wall hanging ! I am concentrating on the alloy at the moment. Its not bad , no scratched but little marks from slight corrosion which don't want to come out with the cutting paste so i think I am going to have to do the sanding, which slightly horrifies me but I am sure it will come back eventually.
1962 3.8 Series One FHC
wilde
Post by wilde » Fri Jan 22, 2016 10:25 pm
Here is what I have done with a second steering wheel found in a junkyard. Black epoxy and wood restored by a local cabinetmaker ! I found the idea when I saw the second Lindner Nocker made by CMC.
Off topic, it's really funny, we never met, but I already know two of the topic's contributors. Rolando38 on the Facel Vega forum and Andrew about DB4 GT, when I have made the entire register. Same guys at the places!
