Air duct lower panel assembly bd35655
grimes6
#1 Air duct lower panel assembly bd35655
Post by grimes6 » Fri May 13, 2016 2:04 am
I am about to start to paint my bonnet but I am unsure I have the correct air duct panel. All the suppliers list the panel for the Series 1 but the series 2 has a different part number. Can anyone supply a pic. of a series 2 panel or confirm if it the same as series 1?
Greg
Post by PeterCrespin » Fri May 13, 2016 2:10 am
If you mean the long duct from bonnet mouth to heater box they are not the same. The S2one has a section pushed laterally to the outboard side to give clearance for an AC compressor.
grimes6
Post by grimes6 » Fri May 13, 2016 2:29 am
The panel fits in the mouth of the bonnet in front of the stoneguard screen and attaches to the lower panel assembly.
Greg
grimes6
Post by grimes6 » Fri May 13, 2016 6:21 am
I have found this site which shows the series 1 panel.Chuck at this site (http://www.monocoque-metalworks.com/mai ... et-panels/) states the following :
Bonnet Air Duct Lower Panel ? Series 1 ? BD16557 ? $48.00. 19-gauge steel. Series 2 is also available ? it is a different size and shape (even though most other catalogs show the same part for Series 1 and 2?) This panel is also available in aluminum.
288gto
Russia
Post by 288gto » Fri May 13, 2016 7:09 am
Hi Greg,
I am assuming you are UK based. Speak to Andy at Hutsons, they make their own, that's where I got mine from (series 2) and it fitted perfectly which is more than can be said for the expensive underpan I got from a well known manufacturer.
Simon[/youtube]
