Series 2 Automatic gearbox leak
Amarksherwood@gmail.com
#1 Series 2 Automatic gearbox leak
Post by Amarksherwood@gmail.com » Wed Feb 28, 2018 3:25 pm
I have a series 2, 2 plus 2, 4.2 1969. There is a leak from the gearbox, red fluid on the garage floor. A local garage told me it was the sump gasket, which has been replaced, but it is still leaking. I wanted to know if anyone has had work done at Stantons in Tonbridge, Kent - http://www.stantonautomatics.co.uk/. They seem very knowledgeable, but I don't want to let someone work on the car who does not know what they are doing. If not these guys, is there anywhere else that could be recommended.
1954Etype
#2 Re: Series 2 Automatic gearbox leak
Post by 1954Etype » Wed Feb 28, 2018 3:53 pm
Don't know anything about these guys. The last 2+2 auto we replaced the sump gasket on we had to straighten out the sump face first. They are only a thin steel and deform very easily. If they didn't straighten it out first then chances are the new gasket will still leak.
Angus 67 FHC 1E33656
61 OTS 875047
Bob.
#3 Re: Series 2 Automatic gearbox leak
Post by Bob. » Thu Mar 01, 2018 8:47 am
There is seal on the manual selector shaft which might be leaking, transmission fluid may then spread and make it look like a pan gasket leak.
Bob
'71 S3
#4 Re: Series 2 Automatic gearbox leak
Post by Amarksherwood@gmail.com » Thu Mar 01, 2018 5:21 pm
Thanks Bob, that is exactly what they said might be the cause of the leak, when I popped in there the other day (without the car) They did say it was an engine out job, do you know if this is true?
Richardhealey
#5 Re: Series 2 Automatic gearbox leak
Post by Richardhealey » Thu Mar 01, 2018 8:39 pm
Hi Bob,
I have a series 2, 2+2 auto box I have taken out of my car,
I think it’s probably worthless. If you need to scavenge parts - give me a shout.
I believe this is in the true spirit of the forum?!
Cheers,
Rich
Bob.
#6 Re: Series 2 Automatic gearbox leak
Post by Bob. » Fri Mar 02, 2018 11:51 am
It looks as if the selector shaft has a flange outboard of the seal which would mean the shaft has to come out to change the seal. Whether this is possible via a combination of access through the removable plate on the left side of the transmission tunnel and removal of the sump pan I don't know. You could try jag-lovers.com as there is likely to be a lot more experience in the US of E Types with auto boxes than in the UK.
Bob
'71 S3
#7 Re: Series 2 Automatic gearbox leak
Post by Amarksherwood@gmail.com » Wed Mar 07, 2018 4:41 pm
Thanks very much for all your advice. I will contact jag lovers and see what they say.
