Back pressure on classic fabs exhaust system ?
Keith in Norfolk
#1 Back pressure on classic fabs exhaust system ?
Post by Keith in Norfolk » Tue May 24, 2016 5:58 pm
Thank you all very much indeed for your input and help.
.First of all I should have mentioned that my car has a part electronic system
no points or condenser just the rota arm and dizzy cap
The car started fine this morning with no problems which leads me to believe
there is nothing wrong with the coil or ignition system.
The problem only seems to happen when driving hard ie overtaking or driving at speed when the engine is at full tempreture .
I think I am inclined to agree with this not being a problem with the exhaust
system and will try what many have suggested and replace the coil and rota arm with the ones suggested and see if that solves the issue.
I will keep you all informed and once again thank you all for your help
caveman
Post by caveman » Tue May 24, 2016 8:06 pm
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#3 Re: Back pressure on classic fabs exhaust system ?
Post by abowie » Wed May 25, 2016 3:41 am
A coil may work perfectly when cold and fail when hot.
Post by mgcjag » Wed May 25, 2016 7:36 am
Keith..check your PM...i sent you one on the day you opened this thread......also why have you started a new thread with the same title instead of continuing the first one...
Keith in Norfolk
Post by Keith in Norfolk » Wed May 25, 2016 10:44 am
Sorry Steve , I hit the wrong button :roll:
