Plastic fuel pipe
Monkeyfinger
Topic author - Posts: 309
#1 Plastic fuel pipe
Does anyone know a good source of the original style hard plastic fuel transfer pipes used on the series 2? I know I could use braided flexible pipe but I want to keep original if possible.
#2 Re: Plastic fuel pipe
SNG sell it with the fittings attached to connect from the filter to the carbs......others on here have just bought the pipe......some one will let you know
Monkeyfinger
#3 Re: Plastic fuel pipe
Great...I want to try with just the pipe. I think I should be looking for semi rigid nylon but perhaps someone will confirm
#4 Re: Plastic fuel pipe
Hutsons sell the correct pipe.
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
#5 Re: Plastic fuel pipe
I bought mine from David Manners Ltd, part number C24757/1M £6.50 per metre.
Monkeyfinger
#6 Re: Plastic fuel pipe
New pipe duly delivered - fitted my banjos and I now have a nice set of pipes fitted as original spec. Thanks for the input all.
#7 Re: Plastic fuel pipe
"I now have a nice set of pipes fitted as original spec."
Can you hit the high note now in "Unchained Melody"?
Mark Gordon
#8 Re: Plastic fuel pipe
Only after a swift kick to the netherlands.
Monkeyfinger
#9 Re: Plastic fuel pipe
You boys crack me up...at least you didn't mention my banjo and my role in Deliverance...
