#1 Reversing light
Posted: Sun Sep 11, 2016 6:31 pm
by nottsman
My reversing light is not working. I've replaced the gearbox switch and cleaned the earth contact. The green wire to the switch and the green/brown from switch to light does not have any power and seems dead. I've bypassed everything with a separate feed and proved the light works. I thought I would rewire it but when I tried this, the fuse (no 7) burnt out and blew.
Any ideas. I'm wondering if I used a replacement wire that was too high amp rating although the fuse is 35 amp rated.
#2 Re: Reversing light
Posted: Sun Sep 11, 2016 6:45 pm
by cactusman
No such thing as wire with too high an amp rating. If the fuse failed it did its job as there is a short to ground somewhere. Check for broken insulation or chafing where wires pass close to metal edges. Do not be tempted to put a fuse with a higher rating or use a bolt instead of a fuse! That way you get an electrical fire....bad thing.
#3 Re: Reversing light
Posted: Sun Sep 11, 2016 6:51 pm
by nottsman
Julian thanks.
Me thinks my car is too precious to risk getting this wrong. I will invest in a mobile auto electrician to check the car over.
#4 Re: Reversing light
Posted: Sun Sep 11, 2016 7:29 pm
by cactusman
Very wise. Electrical fires are spectacular and devastating.
