Steel wheel clamp FHC V12
sihol
#1 Steel wheel clamp FHC V12
Post by sihol » Fri Jun 01, 2018 8:36 pm
Good Evening All
I am trying to locate a wheel clamp for my S3 2+2 V12FHC. I can find BD-36808 for the roadster, but not BD-36809 stocked anywhere
surely if the same wheel then this should fit, or am i missing something.
Appreciate your help. Last item before off to Le Mans
:scratchheadyellow:
lowact
#2 Re: Steel wheel clamp FHC V12
Post by lowact » Sat Jun 02, 2018 1:58 pm
According to the parts manual 08 is for wire wheels, 09 is for "disc" wheels.
71 V12
#3 Re: Steel wheel clamp FHC V12
Post by 71 V12 » Sat Jun 02, 2018 3:12 pm
Mine was also missing from my car as bought. I also could not locate the wire wheel version, and this was back in 2007. In the end I located a shorter clamp of the same design off another model Jaguar, cut in half and welded a length of bar between the handle and threaded end.
Works great.
Good luck
Kevin
