Silencers
Bernie2015
#1 Silencers
Post by Bernie2015 » Sun Mar 03, 2019 9:44 am
I bought 2 of these (see photo)from SNG and tried to fit them yesterday to my 1973 Series 3. They will only fit on one way due to the positioning of the inlet/outlet on the silencer. it seems that the inlet and outlet parts on the silencer have been fitted the wrong way around or the exhaust pipes are incorrect on my car. Does anyone know what outside diameter of the ends of the silencer should be? I have the front measured at 51mm O/D and the rear at 54mm O/D. They would fit my exhaust perfectly if i reversed the silencer but for reasons explained its not possible. Is this a manufacturing fault otr wrong connecting pipes on the car? Any help greatly appreciated.
Bernie 1966 S1 OTS
Bob.
#2 Re: Silencers
Post by Bob. » Sun Mar 03, 2019 4:17 pm
Hi Bernie -Limited access but just had a quick check under my car which has a st st system of unknown origin fitted so no guarantee that everything is to original dimensions.
OD of inlet pipes at entry to the silencers is 2.0" (ie ID of silencer inlet) and distance between centres of the two silencer inletss 9 1/2". OD of outlet pipes at silencer exit points is 1 7/8" (ie ID of silencer outlet) and distance between centres of approx 6".
Hope this helps rather than confuses,
Bob
Bob
'71 S3
baganz.sven@web.de
#3 Re: Silencers
Post by baganz.sven@web.de » Sun Mar 03, 2019 5:18 pm
I would ask SNG if those parts can only be used in combination with the stainless steel pipes.
I have a complete Bell system from SNG in my garage but still wrapped.
If you need support I could measure the parts for you.
Sven
Sven
'71 S3 coupe LHD manual
Bernie2015
#4 Re: Silencers
Post by Bernie2015 » Mon Mar 04, 2019 7:13 am
Thanks Sven I would be realy interested to know the diameter of the inlet and outlets on your new silencer it would then tell me if there is a manufacturing fault
Bernie 1966 S1 OTS
Thor
#5 Re: Silencers
Post by Thor » Mon Mar 04, 2019 8:28 am
The larger pipe is the inlet (front) which allows the link pipe to slot inside the silencer.
The smaller pipe (rear) should have the outside dia the same as the inside dia of the front assuming they have used the same tube,one end is expanded.
Hope this helps. :Scotland:
#6 Re: Silencers
Post by mgcjag » Mon Mar 04, 2019 8:44 am
Hi Bernie....just give Bell a call they are in Wiltshire.....you should have an answer in minutes http://www.bell-steel.co.uk/silencers.htm Steve
Bernie2015
#7 Re: Silencers
Post by Bernie2015 » Mon Mar 04, 2019 8:58 am
Thanks will do
Bernie 1966 S1 OTS
baganz.sven@web.de
#8 Re: Silencers
Post by baganz.sven@web.de » Mon Mar 04, 2019 4:27 pm
Hi Bernie,
I just checked my set.
The front pipes have an outside diameter of 51mm and fit into the silencer without any effort.
I think you can use the silencers only with the Bell pipes.
Sven
Sven
Bernie2015
#9 Re: Silencers
Post by Bernie2015 » Mon Mar 04, 2019 5:19 pm
Thanks Sven its beginning to look like that its a shame SNG never mentioned it if that's the case
Bernie 1966 S1 OTS
#10 Re: Silencers
Post by mgcjag » Mon Mar 04, 2019 5:51 pm
Hi Bernie...did you ask SNG if they would fit.....they do have a no quibble return policy as far as i know....Steve
Bernie2015
#11 Re: Silencers
Post by Bernie2015 » Tue Mar 05, 2019 9:13 am
Might have to go down that route or perhaps buy the whole kit if these silencers are not designed to fit to the original pipes on the car
Bernie 1966 S1 OTS
#12 Re: Silencers
Post by mgcjag » Tue Mar 05, 2019 9:51 am
Hi Bernie.....just for info iv been intouch with Bell exhausts all their E type exhausts are made to fit to original equipment parts.......so providing you have original exhaust Bell should fit.....Steve
Bernie2015
#13 Re: Silencers
Post by Bernie2015 » Tue Mar 05, 2019 10:04 am
Thank you there was no need for that - I have a dialogue going with them already. From the info gleaned above it seems the inlet and outlet on the silencer may have been fitted incorrectly. Thanks for the input all - I will let you know how it turns out.
Bernie 1966 S1 OTS
Bernie2015
#14 Re: Silencers
Post by Bernie2015 » Tue Mar 05, 2019 12:30 pm
Ive just had another look at the exhaust system and it looks old enough to be original. Does anyone happen to know what the outside diameter of original pipes on the Series 3 exhaust system were or where I could find this info? ie the ones that go into the front of the silencers and also the outside diameter of the ones that go out of the back of the silencers?
Bernie 1966 S1 OTS
Whitact
#15 Re: Silencers
Post by Whitact » Tue Mar 05, 2019 2:48 pm
Hi Bernie,
I have an old system in my shed that I believe to be as per original.
The OD of the pipe before the silencer is 2 inches and the OD of the pipe after the silencer is 1 3/4 inches. These are the exhaust pipe outside diameters, not the silencer spigots.
Cheers,
Adrian
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
Bernie2015
#16 Re: Silencers
Post by Bernie2015 » Tue Mar 05, 2019 3:04 pm
Thanks Adrian my exhaust pipes are very similar o/d to yours so originals as well i believe.
Bernie 1966 S1 OTS
lesxjr
#17 Re: Silencers
Post by lesxjr » Tue Mar 05, 2019 3:38 pm
Hi Adrian,
I've been a very long time Jaguar owner/enthusiast but have only recently joined the E type club after buying a 1974 series 3 OTS. As a 'newbie' and not wanting inadvertently to do anything on the forum that isn't proper or highjacking the post, I noticed you mentioning you have an old system. I'm looking for a complete serviceable system including the 4 pipe fantail if possible (with or without front downpipes) and wondered if yours is such, and if so would you consider selling it?
Cheers, Les
Les
Series 3 OTS
BIG53
#18 Re: Silencers
Post by BIG53 » Mon Mar 11, 2019 9:14 pm
Hi Bernie,
I had the same problem with my silencers around 3 years ago, mine went back to bell to be corrected.
Bell must be aware of the problem. I spoke to Tom and they arranged for a courier to collect.
Good luck, I hope you get it fixed!
Allan.
Bernie2015
#19 Re: Silencers
Post by Bernie2015 » Tue Mar 12, 2019 8:37 am
Thats interesting Allen was it the same problem? When we position them in line with the existing inlet and outlet pipes they wont sit together as they are too close.
Bernie 1966 S1 OTS
#20 Re: Silencers
Post by mgcjag » Tue Mar 12, 2019 8:51 am
Hi Bernie...does this help...from the service manual....there are also other detailed drawings in there....Steve
