S3 Covered Headlamp Kit
sideways60
#1 S3 Covered Headlamp Kit
Post by sideways60 » Tue Sep 24, 2019 7:36 pm
Has anyone Brought Fitted These German Kits ? . Russ
#2 Re: S3 Covered Headlamp Kit
Post by mgcjag » Tue Sep 24, 2019 7:52 pm
More details please...what German Kits?...do you have a link to them?
61Elite
#3 Re: S3 Covered Headlamp Kit
Post by 61Elite » Fri Sep 27, 2019 12:33 pm
I installed the headlight kit on my SWB S3 a couple years ago. (Walshien???) It is expensive, but very good quality and very good instructions. It assembles without any cutting of existing sheet metal. It takes time and patience, but I am happy with the final result. It really doesn't look like an original E type headlight assembly, but in my case it fits the car.
Mephistopheles
#4 Re: S3 Covered Headlamp Kit
Post by Mephistopheles » Sat Sep 28, 2019 2:49 pm
Hi Russ,
maybe you are referring to this kit
best regrads
Holger
1973 manual LHD OTS E Type
Holger
sideways60
#5 Re: S3 Covered Headlamp Kit
Post by sideways60 » Thu Oct 03, 2019 8:33 pm
Thanks Guys ,
Interesting design Ideas 61 Elite , Did you Consider fitting S1 Indicator/side Light Units ? .
42south
New Zealand
#6 Re: S3 Covered Headlamp Kit
Post by 42south » Fri Oct 04, 2019 6:50 pm
Take a look at the kit produced by poster Marek
He is uk based, might be relevant after brexit :wink:
I have seen the kit and it is high quality, it has one major advantage over the one referenced above in that marek supplies new diagphram plates, at the back of the bowl, so no cutting is required.
Stephan’s kit leaves the bowl protruding out the back of the diafram plate, which must be cut, leaving the wires exposed.
They are both high quality, I have Stephan’s kit, but in hindsight I like the clean no cutting look of Marek’s.
Mark Brown
kashma77
#7 Re: S3 Covered Headlamp Kit
Post by kashma77 » Sun Oct 20, 2019 4:27 pm
Hello Russ,
I have the Headlight kit from Stefan Wahl and I am very satisfied with it :yellow:
The big advantage for me was that Stefan offers the assembly and did it on my car :fingerscrossed:
greetings
Ralf
1972 Jaguar E-Type Series 3 V12 Coupe
1974 Porsche 911 2,7 Coupe
Ole-xke1974
#8 Re: S3 Covered Headlamp Kit
Post by Ole-xke1974 » Sun Oct 20, 2019 6:07 pm
I am intrigued! Can you explain SWB S3 ?
sideways60
#9 Re: S3 Covered Headlamp Kit
Post by sideways60 » Tue Oct 22, 2019 7:49 pm
Thank you Ralf , Nice , I'm waiting for the Long Chrome strip its on Back order . Russ
61Elite
#10 Re: S3 Covered Headlamp Kit
Post by 61Elite » Sat Oct 26, 2019 12:17 pm
SWB- Short Wheel Base
I do not want to get off track with the thread, but my car started out as a derelict, but straight S3 coupe(California car). I chopped off the top and shortened the car 8 inches. Rebuilt engine, 5 speed box. New Martin Robey (S1 and S2) sheet metal to form the roadster boot. Reinforced ladder frame inside the monocoque for added stiffness. Similar concept to the Eagle Speedster, but with a 5.3.
Also, regarding the Wahl kit. For some reason, the headlight buckets on my car had the original hole for the pigtail wiring welded shut, and a new hole was drilled further forward, which allowed the wiring to exit in front of the headlight panel and thus is "hidden". And yes, I know I need to give it a cleaning this winter.
Ole-xke1974
#11 Re: S3 Covered Headlamp Kit
Post by Ole-xke1974 » Sun Oct 27, 2019 12:36 pm
I know what swb means, but only ever seen a series 3 swb in Jay Leno’s garage.
Thanks for explaining your very interesting project.
