On LHD cars the pedals are at least 105 mm apart, including the accelerator.
On RHD cars the accelerator is 30 mm closer to the pedal box. So, to maintain the LHD spacing I would need to bend the pedals as shown in the following diagram; red = LHD, green = RHD. Trouble is, this would cause the clutch pedal to be 13 mm higher than the brake pedal (as shown).
Alternatively, I could leave the clutch pedal as is and bend the brake pedal half as much, to half-way between the clutch and accelerator, pedal spacing would then be 90 mm instead of 105 mm. The height difference would be negligible.
Has anyone else done this, did it work out ok? Also pls, what is the pedal spacing on RHD S3’s, between the clutch and brake and between the brake and the accelerator?
Thanks for any suggestion.
