I have a series 3, 1971-V12.
I have a Helicoil insert that is sticking out of my oil sump plug hole, l have seen different posts with different suggestions but not a clear description for a solution. If I try to put another helicoil in - should l retap the original thread after removing the insert ( would that be 5/18x18unf. M18x2 ) or drill a bigger ‘clean bore’ and tap/helicoil that? Or…
I read about Time Sert’s, what size should I use? This solution sounds interesting as this may prevent the same problem happening again.
Would you recommend removing the sump to do this?
Many thanks for your help
Bob
Oil sump plug thread
#2 Re: Oil sump plug thread
I would pull the old helicoil out and replace it with one of the same size. Grab it with a pair of pliers and it should come out like a spring.
If that fails then you could drill it oversize.
Do NOT try to put a tap down to straighten out your current helicoil. It will jam in place and be very difficult to remove.
#3 Re: Oil sump plug thread
Thank you Andrew for your reply, l am in Uk for a couple of days and will get the helicoil thread repair kit while here and will try to do as you suggest when l get back to France. I wondered about the Time Sert solution as it may be more durable. I guess the helicoil should be fine l will just make sure l do the oil changes from now on and make sure it is not over tightened. Thank you. Bob
#4 Re: Oil sump plug thread
I use an Autovac to suck the oil out, no mess, no risk of stripping threads, no need to replace copper gasket or jack car up & crawl under!
Randall Botha
'64 3.8 fhc & '51 Mk 7
