Brake Fluid Capacity
#1 Brake Fluid Capacity
I am about to refill the brakes and clutch after replacing/rebuilding all the components (calipers,cylinder pipes).There are no upgrades only original bits other than Rob Beere remote bleeders on the rear. How much fluid will I need for this, I don't want to run out part way thro' the job nor do I want to have unused fluid standing about soaking up water?
Pete G(formally e-bygum)
1971 S3 2+2 OSB
1971 S3 2+2 OSB
#2 Re: Brake Fluid Capacity
How much you need all depends on how you bleed you brakes and if you get all the air out first go.....a litre is enough......but 2 to be sure....iv known some to use 5 lit to bleed their brakes
#3 Re: Brake Fluid Capacity
Thanks Steve. I'll go for 3lt.
1971 S3 2+2 OSB
1971 S3 2+2 OSB
