Thread lensscrew?
Lizzie
Sweden
#1 Thread lensscrew?
Post by Lizzie » Wed Jun 28, 2023 12:29 pm
Anyone know what thread used on the small screws part number C33952-F?
Craig Balzer
#2 Re: Thread lensscrew?
Post by Craig Balzer » Wed Jun 28, 2023 5:35 pm
They are an unusual screw/bolt available at Barratt's
They are very pound of them
I doubt you'd find a local substitute locally
https://www.sngbarratt.com/English(US)/ ... Down=false
Craig Balzer
Colorado Springs, CO, USA
MarekH
#3 Re: Thread lensscrew?
Post by MarekH » Wed Jun 28, 2023 7:33 pm
It's not proprietary. It'll be something like 6BA or the relevant UNF size. I have a shop near me that specialises in things like these but I'm not passing that way again until next Wednesday.
Lizzie
Sweden
#4 Re: Thread lensscrew?
Post by Lizzie » Thu Jun 29, 2023 4:33 am
The problem is not the screw itself, but the threads in the housing. I need to refresh one of them and I don’t think they are UNF.
#5 Re: Thread lensscrew?
Post by abowie » Thu Jun 29, 2023 7:58 am
3/16" (8) UNF is my guess. 36tpi.
If it's 32tpi it's UNC.
If you have a screw measure the diameter and tpi.
That will tell you.
#6 Re: Thread lensscrew?
Post by mgcjag » Thu Jun 29, 2023 8:14 am
#7 Re: Thread lensscrew?
Post by Gfhug » Thu Jun 29, 2023 11:20 am
Lizzie, if you’re happy using stainless screws then you can easily use one as a thread cleaner. With a needle file cut a small V along the length of the thread. This gives it a cutting action and will help clean the hole threads.
A method of cleaning all threads if you haven’t got the correct taps or dies. Take a stainless nut (as they give a sharper cut) file a V or two Vs into the thread and you can clean up bolts quite easily, too.
#8 Re: Thread lensscrew?
Post by Gfhug » Thu Jun 29, 2023 12:37 pm
The screws are 6-32 unc. If you don’t mind them being modern replacements that may not have the correct pozi or Philips head of the originals then they are readily available on eBay, etc.
MarekH
#9 Re: Thread lensscrew?
Post by MarekH » Thu Jun 29, 2023 12:40 pm
That will tell you.
I tried a 6/32" UNC on a spare housing and it wound in perfectly. Use 3/4" length
EDIT:- posted at the same time as Gfhug - how weird
Lizzie
Sweden
#10 Re: Thread lensscrew?
Post by Lizzie » Thu Jun 29, 2023 6:21 pm
Thanks out there for all suggestions.
I will try 6/32" UNC
Best regards
/Anders
