4 weeks ago I hired in the JD43 tool and managed after a few attempts to set my ride height to 6 3/4”. Having pushed up and down on the frame numerous times over the weeks to ensure the ride height returned, it now has dropped to 5 1/2 “.
I deliberately left the height higher than the manual as I had not put in the coolant or oil, oil went in two weeks ago and no drop, coolant in today and now it appears to have shifted down.
I am at a loss as I would not have expected such a drop even considering the additional weight of the fluids added.
I set the cams to their furthest point so I could adjust the ride height if the ride height stayed as set, now it has dropped I can not use this as a means of getting out of jail.
Your thoughts on why this happened would be appreciated, I have gone through the forum over time and read a number of post related to torsion bars unwinding due to age etc, etc.
I am somewhat deflated this afternoon that this has happened knowing this has now halted my project plans for a live run in September, it has taken 5 years to get here .
Also, another niggle on parts, a brand new fan switch t housing which I acquired some time ago from one of the main suppliers let me down, 7 litres in with coolant and a fault in the aluminium casing caused me to halt operation, there was a pin hole in it
All in all a depressing couple of days.
Thoughts most welcome
Paddy
