Floating / diving at speed
#1 Floating / diving at speed
At high speeds the car starts to float and dive all over the place if go over even small undulations in the road surface (for example on motorways). Quite alarming! Before I start attacking anything, any suggestions as to what us most likely to be causing it? Tyres are at 32 lbs all round; suspension rubbers were all replaced 2 years ago; but I'm uncertain as to when tracking etc was last checked. Air getting under front end and causing loss of grip? Suspension issues? Tracking? What might it be?
Gordon James
S3 1971 - Original (JHT) LHD/Auto/Air Con. Re-imported from US via UK in 1994, rebuilt Antwerp. Dk Blue (orig Sable)/Biscuit (orig Beige)
Porsche 911SC 1983
VW T2A Bus 1971
VW Beetle Cabrio 1967 (but bit of a mixture!)
Porsche 911SC 1983
VW T2A Bus 1971
#2 Re: Floating / diving at speed
Sounds like ypu need a thorough safety check over...frames/crackes/ connected to body...all suspension/steering rack...wheel bearings..tyres. brakes.
And alignment...Steve
#3 Re: Floating / diving at speed
How old are the tyres on the car?
#4 Re: Floating / diving at speed
Sounds to me like tracking is out run your hand across the front tyres if it feels rough one way and smooth the other (like a hacksaw blade sharp one way and smooth the other) the tracking is out
Rob 1972 s3 roadster
Aston Martin DB9 Volante
#5 Re: Floating / diving at speed
Of the number of possibilities, I agree that incorrect front wheel alignment is the most likely cause.
Check toe in; if this is incorrect it would cause your symptoms.
Check castor; if this is wrong it will interfere with self centring and make the car feel unstable at speed.
Once you have corrected these problems you can move on to the other things mentioned above.
#6 Re: Floating / diving at speed
Thanks all. Will get on with checks (simplest ones first!) and report back idc.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Porsche 911SC 1983
VW T2A Bus 1971
#7 Re: Floating / diving at speed
First thing I would check would be the front shock absorbers ...
#8 Re: Floating / diving at speed
It could be all the things mentioned so far but I notice you are running tyre pressures at 32 p.s.i all round whereas the Jaguar recommended pressures are 24 p.s.i front and 28 p.s.i rear which is good enough for normal speed upto 120 m.p.h. I'm not saying this will cure your problem but it might help.
Bob
V12 2+2
V12 2+2
#9 Re: Floating / diving at speed
Thanks for advice on tyre pressures. But when I first had the car it was on various pressures in the 20s and was all over the place and terrible to drive. Lifting the pressures to 32 all round has improved things markedly, but of course the high speed weaving issue remains. This forum seems to recommend anything from 30 to 38. Anyone care to add to this aspect for a S3?
G
G
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Porsche 911SC 1983
VW T2A Bus 1971
#10 Re: Floating / diving at speed
I will not run radial ply tyres on an E-Type at 24psi under any circumstances. Lower than 32psi will result in uneven wear. 32 to 34 all round is the sweet spot on my bag of nails.
#11 Re: Floating / diving at speed
1965 S1 4.2 FHC (early)
#12 Re: Floating / diving at speed
If the tyre pressures are OK (suggest 32psi all round) then the weaving is most likely due to incorrect toe in/out at the front. A wheel alignment check will confirm but you cannot use a laser alignment on the E-Type. Gunson make a gauge for home use if you fancy tackling the job yourself.
#13 Re: Floating / diving at speed
The type and manufacturer of the tires can have an impact on recommended pressures, and if you are not running the exact same tire as Jaguar specified back in the day, you would do well to follow the tires manufacturers/supplier recommendation.
Note the variances in these charts from Longstone:
https://www.longstone.com/e-type-jaguar-tire-pressures
#14 Re: Floating / diving at speed
Here’s more variants for you. In the day you also had to decide pressures for normal use up to 120mph and sustained speeds in excess of 120mph (From S3 Manual E165 Issue2);
Then there were winter tyres to choose from (from S3 Service Bulletins);
Once you’ve read enough about tyres, you could also check your anti roll bar bushes and steering rack mounts whilst attending to the wheel track/alignment.
#15 Re: Floating / diving at speed
Had this problem with my Series 3 too. Checked the Geometery and tracking and all was okay. In the end it was the age of the tyres as they were not gripping the road. Renewed all the tyres and floating stopped straightaway. As a rule of thumb our tyres should be changed under 10 years.
#16 Re: Floating / diving at speed
#17 Re: Floating / diving at speed
Advice on getting new tyres noted. Thanks.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Porsche 911SC 1983
VW T2A Bus 1971
