Looking for a replacement - have tried all the usual places but with no success. Any help appreciated.
Spence
1973 Series 3 2+2
Automatic gearbox sump gasket wanted
#2 Re: Automatic gearbox sump gasket wanted
Have you spoken to any of the gearbox refurbishment companies? Ken Evans at Klassik Transmissions might be able to point you in the right direction.
#3 Re: Automatic gearbox sump gasket wanted
I am in the same position at present as mine is leaking.
I bought a sheet of impregnated Cork ( 2mm I think ), when the time comes I'll make my own.
The after market ones looked far too thin.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
Captain Caveman
#4 Re: Automatic gearbox sump gasket wanted
I used a cork one from SNG, not very thick in material but worked nonetheless.. Never as good as they once were in the “good old days” but it is what it is. Good luck.
Link attached
https://cdn.sngbarratt.com/images/produ ... 0da446.png
Link attached
Oct 1971 S3 2+2
Oct 1971 S3 2+2
#5 Re: Automatic gearbox sump gasket wanted
Limora list a gasket here:
https://www.limora.com/en/jaguar/jaguar ... -12-outer/
I also have this problem, but I will not order a gasket until the weather warms up!
David
1973 S3 2+2 in Regency Red
