Do I have an oil pressure issue
doffo25
#1 Do I have an oil pressure issue
Post by doffo25 » Fri Apr 17, 2026 9:02 am
Ive just rebuilt my heads and installed new rings and shells, honed the bores and installed new spin on oil filter.
On cranking the engine (plugs removed) ...I get no oil pressure at gauge...tho I did get oil issuing from slackened cam feeds. A friend of mine (who worked in engine development) suggested firing her up which I did. Sure enough gauge read 50psi at 1000 revs. However I still get no reading on cranking alone and I seem to remember before the rebuild I did get a cranking reading.
Should I be worried?!!
Thank you
David
David Offord
1972 Series3 ots
#2 Re: Do I have an oil pressure issue
Post by mgcjag » Fri Apr 17, 2026 11:59 am
Hi....almost all the oil drains back into the sump when engine is off.....as you crank the pump starts to suck up oil and build pressure.....engine fireing speeds this up..
but on cranking alone it can take quite a while a minute isn't uncommon or even longer....Steve
MarekH
#3 Re: Do I have an oil pressure issue
Post by MarekH » Mon Apr 20, 2026 6:17 am
I don't think it'd take a minute or longer to get oil pressure.
The sender is a bimetallic type and so is the gauge. That means they will respond very slowly when initially fed a signal. Prolonged cranking without a start will also deplete the battery somewhat and so the gauge will not have sufficient voltage across it to register very much, exacerbating the problem.
By contrast, a mechanical gauge will probably pick up very quickly, dependent only on how much oil was left sitting in the feed lines and galleries.
John37
#4 Re: Do I have an oil pressure issue
Post by John37 » Tue Apr 21, 2026 11:10 am
You could try an Accusump. It stores oil under pressure and releases it into the engine on startup. I've never used one but the theory is good and folks who have them support that. They're probably a good idea especially on engines that sit for a long time.
#5 Re: Do I have an oil pressure issue
Post by abowie » Wed Apr 22, 2026 1:10 am
Your oil pressure with the engine running looks fine. I would not be concerned.
doffo25
#6 Re: Do I have an oil pressure issue
Post by doffo25 » Wed Apr 22, 2026 2:52 pm
Thanks guys for your replies!
My car does certainly have a lazy cranking speed. I was just concerned that when cranking for e.g compression testing... that oil might not be circulating. I will get hold of a mechanical gauge to check.
best
David
David Offord
1972 Series3 ots
MarekH
#7 Re: Do I have an oil pressure issue
Post by MarekH » Wed Apr 22, 2026 6:47 pm
If you are worried about lubrication during extended cranking when doing a compression test, get a garden sprayer and decant some of your oil into the sprayer. With the nozzle removed, these sprayers will have the same thread as the oil pressure sender and you can thus easily pump oil into the galleries and bearings with the main oil sender removed. With the ignition key in the second position, you'll have the bonus of seeing the oil light go out as you do it, demonstrating 3-5psi of oil pressure. You'll also hear the oil hissing out of the camshaft bearing caps from whence it drains back down into the sump.
doffo25
#8 Re: Do I have an oil pressure issue
Post by doffo25 » Thu Apr 23, 2026 8:52 pm
Thank you Marek.
Are you saying that with extended cranking on a car with no lubrication problems, oil pressure might not be sufficient to lubricate bearings?
David
David Offord
1972 Series3 ots
MarekH
#9 Re: Do I have an oil pressure issue
Post by MarekH » Fri Apr 24, 2026 6:19 am
No, I merely outlined a procedure explaining how to lubricate the bearings without having to crank the engine, plus a method that demonstrates that the garden sprayer produces in excess of 2-3psi.
