Air con not working
Dave Maddock
#1 Air con not working
Post by Dave Maddock » Sat May 07, 2016 7:19 pm
HI, me again. Series 3 OTS
Not had the car long and am trying to de-bug. The air con isn't working, I turn the right hand knob, nothing. No fans run, compressor doesn't seem to be kicking in.
Any ideas most welcome.
caveman
Post by caveman » Sat May 07, 2016 7:34 pm
Hi Dave,
It may just need a re-gas.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
Dave Maddock
Post by Dave Maddock » Sat May 07, 2016 7:43 pm
Hi Steve
I will try this, but could I be that lucky? The fans don't blow, nothing happens at all. When my daily driver (bmw) needed gas it a least was blowing air but warm.
Don't know with the etype, would lack of gas means the fans would be cut out?
Thanks for getting back.
Post by PeterCrespin » Sun May 08, 2016 12:46 am
Many AC systems prevrnt compressor damage by isolating it if the refrigerant/oil mixture is low or lost. Hkse er, if you are converting to RHD you'llp have to lose the AC anyhow
Dave Maddock
Post by Dave Maddock » Sun May 08, 2016 8:06 am
Thanks Pete
caveman
Post by caveman » Sun May 08, 2016 2:33 pm
Hi Dave,
As Pete has eluded to, the AC system has a fail safe to protect compressor etc. The fan may also be part of this too.
Some modern cars have independent fans for both AC and engine cooling.
I had a modern Audi a few years ago and the AC always blew hot air and the separate AC fan never ran until I found a loose earth cable, (from AC relay), never fitted at factory. The fan then worked once refitted and AC was on and gas was confirmed and charged.
:wavegreatbritain:
Dave Maddock
Post by Dave Maddock » Sun May 08, 2016 3:36 pm
Thanks Steve
I am coming round to the fact that a pool of green liquid and ac not working are linked....
Many thanks
