#1 Reverse lamp switch
Posted: Fri Feb 10, 2017 8:42 pm
by EDW3694
I have a manual S3 2+2 and am trying to get the reversing lamps to work. I'm wondering where the switch is and what is the best way to get at it? Also is the correct reverse lamp bulb 21w?
#2 Re: Reverse lamp switch
Posted: Mon Feb 13, 2017 12:03 am
by Dave123m
Hi Simon,
The switch is screwed into the top of the aluminium gearbox cover & is operated when the reverse selector moves.
I am unsure if you can reach it from below (doubt it) but you would need to remove the exhaust & heat shield to even try.
Alternatively you can definitely access it by removing the gearbox tunnel lid from inside the car but this is a fairly significant exercise & I would only recommend it if you have ruled out all other electrical issues.
Good luck with your investigations.
#3 Re: Reverse lamp switch
Posted: Mon Feb 13, 2017 7:49 am
by MarekH
The reverse lamps are fed by a green wire to the top of the gearbox cover (the source of which you may be able to trace). It then becomes a green/brown wire. Access is by removing the tunnel cover, although you may be able to see or feel from below if there is no foam on top of the gearbox.
The bulb for the little square MGB reversing lights is a puny festoon bulb which gives no useful illumination anyway compared to the LED option, which you can see under the "series2 aesthetics" thread from a while ago.
#4 Re: Reverse lamp switch
Posted: Tue Feb 14, 2017 7:43 pm
by EDW3694
Thanks for the info. Ive got all the other switches and lights working on the car so I looks like I've left the trickyist one to last.
