#1 Series 3 ignition
Posted: Sat Apr 08, 2017 7:59 am
I'm having trouble with getting the engine started for the first time in many many years. I have re-built the engine (the original was destroyed and replaced with a XJS HE engine.)
I have checked the timing 12 deg BTDC with mark on the rotor opposite the pick up
The timing sequence is correct
The No. 1A TDC is on the compression stroke
New high torque starter, new battery, but it still turns slowly.
There appears to be no suction on the carbs when turning it over.
The balance resistor is getting HOT (don't think this should happen should it ?)
The engine is on a test rig prior while bodywork is being sprayed, so no air filters or exhausts, just the down pipes.
It did run once for about 15 secs but not again since.
I know that the original ignition system was notorious for it's unreliability.
Has anyone had any experience with Lumenition ignition on these V12's. as an alternative?
