modified rear brake inspection hole
jonhall88
#1 modified rear brake inspection hole
Post by jonhall88 » Fri Apr 21, 2017 8:05 pm
Sorry to be a pain but I cannot find the post from the chap that made an inspection hole for his rear brake / handbrake, he posted some good phots and I intend doing it to adjust my handbrake
thanks
jon
1974 ser 3
MarekH
#2 Re: modified rear brake inspection hole
Post by MarekH » Sat Apr 22, 2017 6:55 pm
You may struggle with this. Consider how much carpet has to be cut away for another inspection hole. The other two for the brakes are neatly hidden behind a large flap of carpet but this one would have to remove carpet from the centre of the car.
Once the exhust is removed, there is very good access from under the car. As the caliper mechanism has a self adjusting ratchet, there ought to be little further user input once it has been initially set up to work.
