Where to get covers for the leather at the doors?
Topic author - Posts: 62
#1 Where to get covers for the leather at the doors?
Jaguar E-Type S3 1971
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#2 Re: Where to get covers for the leather at the doors?
Actually, they are vinyl . Any upholstery shop will have a selection. No worries.
#3 Re: Where to get covers for the leather at the doors?
Thanks - but how does it originally look like? Do you have a photo?
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#4 Re: Where to get covers for the leather at the doors?
The best people for this sort of thing are BAS in South Wales .
#5 Re: Where to get covers for the leather at the doors?
Hi Stefan.....is this what you are looking for this is fron my S2 not sure it its the same for a S3..i can see that it looks like you have trimmed useing leather which is quite thick and with the trim covering it could make the doors too tight to close..the trim in the photo with the herringbone patern is i think unavailable but there are other similar versions
Edit...for some reason i think the trim on the S3 had a more furry look
#6 Re: Where to get covers for the leather at the doors?
I would try XK's Unlimited in California. 800 444 5247. Ask for Steve. Knowledgeable guy. .
#7 Re: Where to get covers for the leather at the doors?
Not, I'm afraid, a very convenient supplier for GermanyJJC wrote:I would try XK's Unlimited in California. 800 444 5247. Ask for Steve. Knowledgeable guy. .
#8 Re: Where to get covers for the leather at the doors?
Vinyl ("Titanfast") or furry ("Furflex") as preferred:
http://www.woolies-trim.co.uk/c-39-edge-trims.aspx
1969 S2 FHC - 1R20258
#9 Re: Where to get covers for the leather at the doors?
Thanks Simon. Do you know which type i need for the S3 and which color matches the jaguar beige / cinnamon.
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#10 Re: Where to get covers for the leather at the doors?
Do i need 264-BG or 235-BG?
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#11 Re: Where to get covers for the leather at the doors?
Neither...they are the wrong thing.....as they also have a rubber seal part attached....the best thing to do is contact one of the trimmers.. BAS ..Aldridge.... etc....and get them to send samples....either the vinyl type or the furry one....they will know what type your car should have....or you can send a sample of your colour so they can get the closest match
You need something like this called edge trims http://www.woolies-trim.co.uk/c-329-clo ... -trim.aspx
http://www.woolies-trim.co.uk/c-330-pvc-edge-trims.aspx
#12 Re: Where to get covers for the leather at the doors?
Thanks!
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#13 Re: Where to get covers for the leather at the doors?
How bizarre! I thought I'd originally cut and pasted the same link as you - hence the accompanying text. Link now edited. Most odd.....mgcjag wrote:Neither...they are the wrong thing.....as they also have a rubber seal part attached
