Doorlock reversed / mirrored on each door / side?
disaster123
#1 Doorlock reversed / mirrored on each door / side?
Post by disaster123 » Tue Aug 08, 2017 8:27 pm
Hello,
my door lock is reverse on each side / door.
So on the left door i've to use the key in up position on the right door in the down position. I also have to lock in reverse direction.
Is this normal? Can i fix it?
Greets,
Stefan
Jaguar E-Type S3 1971
VW Käfer 1200 1967
MG MGB 1967
#2 Re: Doorlock reversed / mirrored on each door / side?
Post by abowie » Wed Aug 09, 2017 1:06 am
Normal. 20 chracters
disaster123
#3 Re: Doorlock reversed / mirrored on each door / side?
Post by disaster123 » Wed Aug 09, 2017 5:44 am
OK strange. Didn't expect this from a car like this. Are you sure?
VW Käfer 1200 1967
MG MGB 1967
panamacarrera
#4 Re: Doorlock reversed / mirrored on each door / side?
Post by panamacarrera » Wed Aug 09, 2017 8:38 am
My '71 S3 has the same arrangement... I too thought it unusual but seems the way they built them, I wonder how much BL saved per car with this arrangement. Weirdly my '69 MGB has the more logical/expected arrangement.
'71 S3 OTS
disaster123
#5 Re: Doorlock reversed / mirrored on each door / side?
Post by disaster123 » Wed Aug 09, 2017 9:06 am
same to me for my 67' MG MGB which has it in the correct way.
OK thanks. very strange
VW Käfer 1200 1967
MG MGB 1967
Ikebaddog
#6 Re: Doorlock reversed / mirrored on each door / side?
Post by Ikebaddog » Wed Aug 09, 2017 9:15 am
Noticed the same on mine this weekend, characterful....I like it.
S3 2+2 1971
#7 Re: Doorlock reversed / mirrored on each door / side?
Post by abowie » Wed Aug 09, 2017 9:50 am
disaster123 wrote:OK strange. Didn't expect this from a car like this. Are you sure?
Yes.
John_Mann
#8 Re: Doorlock reversed / mirrored on each door / side?
Post by John_Mann » Thu Aug 10, 2017 12:03 pm
disaster123 wrote:Hello,
Greets,
Stefan
Yes quite normal, as unusual as it may seem.
Can you fix it? :scratchheadyellow: Well if you change it you would break it not fix it.
John Mann
1972 S3 Jaguar E-Type 2+2
1976 Jaguar XJ4.2C
2007 Jaguar XKR Portfolio
disaster123
#9 Re: Doorlock reversed / mirrored on each door / side?
Post by disaster123 » Sun Aug 20, 2017 12:18 pm
Ok thanks. Just didn't expect this. My MG and VW have "corrrect" locks
VW Käfer 1200 1967
MG MGB 1967
