#1 series 3 knocking from rear end
Posted: Sat Aug 15, 2009 8:02 am
by clive V12
I am new to this forum and would like to know if anyone can help me?
My V12 has just started to make a knocking sound from the rear, I have lifted it up onto stands and put it into drive but can`t see anything catching,it does seem to orignate from the diff or brake area.
The sound increases with speed.
Can anyone help ?
Posted: Sat Aug 15, 2009 5:49 pm
If the sound is speed related, increasing in frequency the faster you go, but without being a heavy knock, then a likely candidate is one of the driveshaft dustshields. These should be secured by a jubilee clip, and the two halves are riveted together, but people forget to do up the clips after greasing, or the rivets rot away . You may find that you cannot reproduce the knock on stands because the droop of the suspension arms affects the juxtapositon of whatever is knocking
Posted: Sat Aug 15, 2009 9:41 pm
by clive V12
The noise is a heavy knocking and is speed related but not the dust shields.
Thanks for the advise.
has anybody else got any suggestions ?
Thanks,
Clive
Posted: Mon Aug 17, 2009 1:29 pm
Posted: Mon Aug 17, 2009 1:45 pm
by Aldeburgh
As david says, sounds very similar to my problem
http://etypeuk.com/forum/viewtopic.php?t=1109
You can only see it when the car is supported on the wheels... when jacked up the spring relaxes and straightens - you need an inpsection pit or a four-poster for things to be obvious.
Good luck
Posted: Mon Aug 17, 2009 7:58 pm
by clive V12
Thanks for that info guys, I will take a look tomorrw.
Sounds like this could be the answer as I did notice the a mark on the UJ and it is toching the spring.
Let you know more tomorrow.
Thanks Clive V12
Posted: Tue Aug 18, 2009 6:47 pm
by clive V12
Hi Guys,
Thanks for the advise, you are totally correct.
ONE BROKEN SHOCK !
I will now start ordering the bits to replace all shocks,springs,discs and pads.
Thanks again,
Clive V12
Posted: Tue Aug 18, 2009 7:49 pm
by e-bygum
I have not heard that broken rear shocks was a problem on S3s and we have two reported in as many weeks!
It would be interesting to know if there is anything common in these instances, i.e.
-what type/make of shocks were they?
-how long had they been in use?
-what type of driving had they experienced (hard driving on twisty lanes, track days etc.)?
- were you aware that something had gone wrong at the time of failure?
- are there any modifications to the rear suspension etc?
Just interested.
Posted: Tue Aug 18, 2009 8:18 pm
by clive V12
Hi Pete & All,
information so far on broken shock;
I think it has been on the car fron new and therefore standard, no mods,
I have driven the car quite slowly just the odd fast pull away,
The knocking was the first sign of the problem,
I will update you when I strip the back end in a couple of weeks.
Hope this helps.
Clive
#10
Posted: Tue Aug 18, 2009 9:52 pm
by e-bygum
Thanks Clive
The shocks don't owe you much then.
#11
Posted: Wed Aug 19, 2009 9:55 am
by Aldeburgh
Couldnt tell if my broken shock was from new but I doubt it as the suspension had been generally gone over during a reasonably thorough restoration about 5 years ago.
There was no bang when it went and not much difference in the driving behaviour immediately afterwards apart from the knock... but I was not hurling it into corners admittedly. So far as I can tell it went during overtaking at about 60mph.
Harry at Etype uk fixed the problem for me with his customary efficiency and said he had never seen a shock fail like that before, arguing that it is far from a commonplace occurence... intriguing coincidence to see two like that so close together.
