Today I removed the entire choke cable, inners and outers. Removed the inner cable, sprayed a whole lot of carb cleaner through the outers, let it dry, squirted graphite power down the outers, cleaned the new inners (which happen to be slightly smaller in diameter) with steel wool, and then installed everything.
Now choke works as it should
(Think I'll have to replace the choke knob anyway...)
