Which Brake Fluid?
dooley1414
#1 Which Brake Fluid?
Post by dooley1414 » Sun Oct 08, 2017 7:28 pm
Hi all.... I have an ex. US Series 3 V12.... and was wondering what brake fluid to use? I don't know what's in it at the moment but is it best to use dot 3 or dot 4 thanks.... Des.
Ex. Texas Import 1971 Series 3 V12
Des. Suffolk.
#2 Re: Which Brake Fluid?
Post by chrisfell » Sun Oct 08, 2017 7:34 pm
I always Use DOT 5.1. Others will tell you different, but I ignore them.
#3 Re: Which Brake Fluid?
Post by Series1 Stu » Sun Oct 08, 2017 7:45 pm
:yeahthat:
Agree with Chris. Although anything but DOT 5, which is silicone and doesn't have any lubricating properties.
Perversely, DOT 5.1 isn't silicone based so it's good to use.
dooley1414
#4 Re: Which Brake Fluid?
Post by dooley1414 » Sun Oct 08, 2017 10:22 pm
Many thanks to you both. 5.1 it is then.
Des. Suffolk.
#5 Re: Which Brake Fluid?
Post by abowie » Mon Oct 09, 2017 4:43 am
Dot 3, 4 and 5.1 are mineral (oil) based fluids, and are cross compatible. The higher the number the higher the boiling point, and cost.
Dot 5 fluid is silicone based and is not compatible with mineral based fluids.
#6 Re: Which Brake Fluid?
Post by chrisfell » Mon Oct 09, 2017 6:41 am
I buy my DOT5.1 in bulk, as I have three cars and a motorcycle requiring fluid changes which I do every two years. However, I don’t buy it in four or five litre cans, but in 500ml bottles. So there is always one bottle unopened, should I have to bleed a system after (say) dropping the rear cage to repair a prop shaft. Search the interweb, check out eBay and Amazon, there are plenty of suppliers who’ll help reduce the cost.
JJC
#7 Re: Which Brake Fluid?
Post by JJC » Sat Nov 25, 2017 10:35 pm
Always a matter of opinion, but Dot 3 has worked for me for years. These are street cars, not race cars, so a higher boiling point unnecessary.
71 V12
#8 Re: Which Brake Fluid?
Post by 71 V12 » Sun Nov 26, 2017 8:55 pm
I had the same query a few years ago and enquired with AP. Their engineer recommended DOT 3 due to having a higher lubricity than DOT 4. Seems to work well in my V12.
Kevin
