#1 Is there a visual difference?
Posted: Mon Feb 05, 2018 4:40 pm
I wonder if you knowledgeable people can help.
Since owning the car (1 month) it has always been temperamental when starting (both hot and cold) also had a misfire once it got up to temperature at higher rpm, now it wont start at all.
Its getting fuel to the carbs which are in a good condition having recently been refurbished and balanced by the previous owner.
There is no spark at the plugs. My first thought was to upgrade the Ignition system (the kits are around £450) as the original system by all accounts is unreliable.
The previous owner spent a lot of money on the car, he told me the distributor and coil are new but he is unsure if it had the full conversion kit, so my question is are there any visual difference or identifying markings/numbers between the original Opus system (Distributor, Amplifier, Ballast resistor and coil) and the upgraded HE kit?
Any thoughts what to check for no HT spark?
