Hi Guys ,
I am close to now getting my imported USA LHD series three on the road legally in the UK.
What do I need to do on the front headlights to comply with the MOT test here ?
Also if I need to change anything what is the best upgrade parts to fit Headlights ?
Many Thanks Brian Tilt.
Headlights
#2 Re: Headlights
Hi Brian,
I used these: https://www.carbuildersolutions.com/uk/ ... side-light
With the relay mod to the wiring and Nightbreaker bulbs. Much better than the standard set up and almost as good as a modern for night driving.
Cheers,
Cheers,
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
S3 OTS & FHC
S1 FHC
XK140 FHC
#3 Re: Headlights
Dear Brian,
You need headlights which dip to the right. There are plenty of options available as Minis and Land Rovers used the same lights. Replacement H4 style housings which use a digfferent bulb to the original sealed beams are also available.
For the indicators, you need to replace the all-red rear indicator lenses with ones which make your rear indicators to be amber instrread of red.
#4 Re: Headlights
Isn't that dip to the left for RHD, Marek?
#5 Re: Headlights
Yes, that's exactly right.
This may also expain why nuts seem to get tighter, no matter how much I undo them.
#6 Re: Headlights
In Aus there was also requirement for the parking lights to be white and front facing instead of the sidelights. I was buying a bunch of stuff from SNGB at the time so I added in the RHD lights with the integral parking lights, SNGB code QRB4698. This was a few years back. Then I got rid of the US sidelights for a much cleaner look.
For the rear blinkers I thought to wire in the US rear orange sidelights. In the end not, I discovered that red flashers are tolerated here. Happy about that, imo the UK design stoplights are a bit unobtrusive.
