Dear colleagues,
can someone tell me which cable/hose goes through the left side grommet in the trunk?
I have marked it in the attached photo.
Thanks for help
Sven
Cable/Hose
baganz.sven@web.de
Topic author - Posts: 157
#2 Re: Cable/Hose
Sven,
this hose is connected to a rigid pipe that goes ubderneath the car up to the the air pump mounted on the engine. There is also an expansion tank fitted between the rear fender and the tank.
The aim is to "drain" the gaz generated by the petrol.
Jérôme
Jérôme
Jérôme
E type Series 3 - 2+2 1972
Peugeot 304 Cab 1971
Jérôme
baganz.sven@web.de
#3 Re: Cable/Hose
ah, very interesting.
Might be my E doesn't have it because it is a german car which doesn't have the Emission Control System used in the US.
Sven
Sven
Sven
'71 S3 coupe LHD manual
#4 Re: Cable/Hose
Earlier (?) setups had it going to the charcoal canister (under the battery).
#5 Re: Cable/Hose
On my UK car this pipe just vents from the fuel breather tank (by fuel filler) to atmosphere above the rear IRS cage.
I know this as I removed the fuel tank & dropped the IRS last week to do some work & confirmed the fuel pipe routes before I removed things.
Hope this helps.
Dave.
Hope this helps.
Dave.
Barn Find Series 3, 2+2;
Pace Petroleum Company Car of Aston Martin Chairman Victor Gauntlett
Unused 25 Years; found 13.01.12 (38052 Miles); returned to road 16.05.12
Aesthetically unrestored, driven to Le Mans Classic (x4), Switzerland, Italy, Gibraltar
#6 Re: Cable/Hose
Dave, my guess is yr vents been disconnected. Can't imagine any logic that would vent the fuel tank into a confined space above the exhaust pipes and brake disks. I'm believing that all versions had the fuel tank vent directly to the charcoal canister, early charcoal canisters (e.g. mine) had outlet directly to atmosphere, later (?) it seems the outlet from the canister was piped to the RHS air cleaners, as per the parts manual diagram.
Jérôme, the air pump pushes filtered air into the exhaust ports. I cannot imagine any logic that would justify pumping fuel vapour into the exhaust ports?
Both these arrangements (modifications) seem potentially dangerous to me.
