#1 Automatic Transmission Fluid Drain and Refill?
Posted: Sun Apr 08, 2018 11:37 am
Hi all.... this might be a silly question or not but I'm under the Jag. at the moment replacing the rear Engine/Transmission Spring.. Bush and Seatings and I thought while I'm under here I will drain and change the Automatic Transmission Fluid but I can't seem to find a drain plug? do I have to take the pan completely off to Drain the Fluid? and where do I refill from? Oh and while the Pan is off if I have to take the Pan off is there a filter I should change or anything else while it is off?.... Thank You.... Des.
