E-typeguy
Post
by E-typeguy » Fri May 18, 2018 6:26 pm
Gents,
This was sold to me as a Series 3 Gearbox cover. On receipt, my feelings say otherwise.
I am in the process of a Series 3 auto to manual conversion. Could one of you all please tell me if I am correct ? I would appreciate the help. Thank you!
Wes
1972 Jag E type coupe - Series 3
1968 Jag E type FHC - Series 1.5
AussieEtype
Post
by AussieEtype » Fri May 18, 2018 11:38 pm
Does a manual gearbox cover fit the auto transmission tunnel which is a bit wider than the manual.
I also did a conversion and was sent a fibreglass version that fits the auto tunnel but the top where the gear lever comes out at the top.
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
E-typeguy
Post
by E-typeguy » Sat May 19, 2018 4:26 am
Hi Gary,
It seems to be short. I was told it was a Series 3 cover but I think not.
Its made out of sheetmetal which I guess is a plus for a earlier car.
Wes
angelw
Post
by angelw » Sat May 19, 2018 10:30 am
Hello Gary,
The transmission tunnel of an Auto and Manual are the same for an S3. Only the Tunnel Top Cover is different.
Hello Wes,
The Gearbox Cover shown in your picture is not from an S3. Following are picture of a correct S3 Gearbox Cover. The Fibre Glass units from SNG Barratt and others are a rubbish fit and require quite a bit of work to have them fit reasonably.
angelw on Sun May 20, 2018 8:00 am, edited 1 time in total.
E-typeguy
Post
by E-typeguy » Sat May 19, 2018 4:33 pm
Thank you very much for the clarification. The photos are a huge help.
I will be sending this one back to the seller.
Wes
