In the boot or not
MLBS3V12
#1 In the boot or not
Post by MLBS3V12 » Tue May 22, 2018 6:37 pm
My S3 is an EFI one and I ve not yet decided where is the best place to fit the ECU, in the boot orin the passager side.
Does someone has already choosen and why?
Le chemin sera long!...
jagwit
#2 Re: In the boot or not
Post by jagwit » Tue May 22, 2018 8:21 pm
I mounted my ecu in the passenger footwell, to the downwards sloping "ceiling" above the passenger's shins. There is a possibility that the passenger can kick the ecu or the cable connector, but a protective plate can be mounted over it. Cables can be fed through the removable panel (I made a new panel to keep the original) where the steering column would have gone through.
Mount it in a way that makes it easily removable, and easy to plug the cable in that goes to your tuning pc.
Best Regards
Philip
