#1 Vacuum pipes
Posted: Fri Sep 06, 2019 8:42 am
This is UK RHD 1973 car
I am trying to improve the running idling. The car tends to vary the revs at idle. Not dramatically just a few hundred revs. I am looking for vacuum leaks, reading I am getting myself a bit confused.
I believe I have vacuum retard with vacuum unit on the dizzy pointing towards the back of the car. The pickup for the pipe is pointing towards the dizzy.
Rather than from the bottom of the LH rear carburettor the vacuum retard is connected to the rear of the LH inlet manifold. This looks original rather than a later modification. The pipe under the carburettor is unplugged, shouldn't this be plugged?
Also the bypass valves are not connected to the vacuum and just left open. Shouldn't they be either plugged or connected to the vacuum?
