Recalibrating the Speedo
sideways60
#1 Recalibrating the Speedo
Post by sideways60 » Tue Oct 15, 2019 8:09 pm
ive gone from 3.54 to 2.88 , a drop of 19% to 0.81 , so is there a choice of Different Speedo Drives ? , Whats the Way Forward Guys ? , ta Russ
#2 Re: Recalibrating the Speedo
Post by Gfhug » Tue Oct 15, 2019 8:22 pm
Speak to Speedograph Richfield who will recalibrate the Speedo for you and give the unit an overhaul
#3 Re: Recalibrating the Speedo
Post by mgcjag » Tue Oct 15, 2019 10:16 pm
Hi Russ....the way forward is to have your speedo recalibrated as Geoff mentions above..changeing the speedo drive is not an option......Steve
#4 Re: Recalibrating the Speedo
Post by abowie » Tue Oct 15, 2019 11:49 pm
mgcjag wrote: ↑
Well it sort of is given that you can buy geared correction boxes that connect to the speedo drive and correct for diff changes, but I agree that the only sensible thing to do is get SR to overhaul the existing unit and put in the proper gears. This ensures the odometer remains correct too.
lowact
#5 Re: Recalibrating the Speedo
Post by lowact » Wed Oct 16, 2019 12:56 am
Here are instructions for recalibrating Smiths speedo and odometer ...
https://1drv.ms/b/s!AiSPBKa26IcchM5cQkn ... A?e=fQijSw
sideways60
#6 Re: Recalibrating the Speedo
Post by sideways60 » Thu Oct 17, 2019 7:54 pm
Thanks Guy's . Russ
Fspp369
#7 Re: Recalibrating the Speedo
Post by Fspp369 » Thu Dec 12, 2019 6:09 pm
Speedo repairs and refacing.
Try this guy :
FLANNERY SPEEDOMETER REPAIR
Www.magnetic-speedometer-repair.com
He’s good and does a great job with “proper” clocks as well.
Peter.
Peter {XKE V12HE efi}
XKRS
Octavia VRS.
sideways60
#8 Re: Recalibrating the Speedo
Post by sideways60 » Sat Dec 14, 2019 6:43 pm
Thanks for the advise , I Went for Speedograph Richfield , 10day Turnaround , Nice Job , I Checked their Work with a Fancy GPS afterwards , i was 1mph out at 70mph if That , Very Happy to Recommend them . Russ
