#1 Alternator Problems
Posted: Tue Oct 15, 2019 3:02 pm
by panamacarrera
Hi All
I'm having problems with the charging system on my S3.
The engine has been out for the last 18 mths, charging system was working fine before engine removal but now everything is back together- nothing but the red warning light.
From the below post I've tested all the prescribed links and everything has good connections.
There's good battery voltage at the alternator B terminal
Just 2v across the control box +ve and -ve terminals...?
I'm stuck. Has anybody ant suggestions for a next step, or do I just give up and visit an autoelecrician?
Thanks guys
Nigel
http://forum.etypeuk.com/viewtopic.php? ... or#p118838
#2 Re: Alternator Problems
Posted: Tue Oct 15, 2019 4:56 pm
by driver
Unless you want to keep everything original, why not just fit a modern alternator.
very easy to fit and no problems constantly checking and vetting old components.
After doing all the other jobs on the car I just decided I just wanted to just to drive and enjoy the car and this seemed the easy option. :swerve: :drinkingcheers:
All the best Rob Gill.
#3 Re: Alternator Problems
Posted: Wed Oct 16, 2019 6:56 am
by panamacarrera
Thanks Rob, a good suggestion but all through the work I've done on the car I've gone for originality and don't plan to change now.
Thanks again
Nigel
#4 Re: Alternator Problems
Posted: Wed Oct 16, 2019 7:11 pm
by driver
Ok, I take your point but after 1500 hours input and a change of working circumstances (new business venture)
I just want to jump in and cruise! :bigrin: i have kept all the original parts though.
All the best Rob :P
#5 Re: Alternator Problems
Posted: Sat Oct 19, 2019 11:34 am
by Ole-xke1974
You might want to charge some suspicious connections, especially the low current ones like the brush connections on the generator itself.
FYI, I have a low glowing charge (ign) light even when the voltmeter is indicating 14 volt on the battery (verified with a Fluke DVM)
Cheers ....... Ole
#6 Re: Alternator Problems
Posted: Mon Oct 21, 2019 8:28 pm
by panamacarrera
Sorted!
In the end I went to a local auto electrician who checked everything, cleaned the brushes and adjusted the earth connection through the cable holder and hay presto everything is working fine.
Thanks to all for your contributions.
Nigel
#7 Re: Alternator Problems
Posted: Mon Oct 21, 2019 11:18 pm
by Ole-xke1974
Good news. Thanks for the heads up .......... Ole
