#1 Strange noise
Posted: Sun Dec 08, 2019 6:06 pm
by driver
Hi Rob Gill here ,
the engine on my v12 seems to run well (good oil pressure no noises etc ).
BUT ,I HAVE ALWAYS BEEN AWARE OF SLIGHT TINNY /METALIC NOISEJUST OCASIONALLY ON THE ENGINE OVER RUN FROM LOW REVS ,I VERY RARELY GO OVER 2500/3000 RPM.HAVE CHECKED ALL THE USUAL MOVING PARTS AND HEAT SHEILDS ETC.THE TIMING CHAIN GIVES OFF NO NOISE ON TICK OVER OR ON NORMAL RUNNING.I AM WONDERING IF IT COULD BE A WORN TENSIONER OR GUIDE …..ANY THOUGHTS OR IDEAS ON THIS ONE GENTS.
THANKS IN ANTICIPATION
ROB :scratchheadyellow:
#2 Re: Strange noise
Posted: Tue Dec 10, 2019 1:53 am
by Ole-xke1974
Rob,
what do you mean by overrun from low revs ?
I'd expect a tinny or knocking noise under acceleration if you have one or more of these:
  • Lean fuel mixture
    Incorrect ignition timing
    Wrong type of spark plug
    Poor quality gasoline
Cheers ........ Ole
#3 Re: Strange noise
Posted: Tue Dec 10, 2019 11:16 am
by ManniB
Rob,
don't forget to check your exhaust manifolds for a leak. It can sound much like what you describe.
- Manfred
#4 Re: Strange noise
Posted: Wed Dec 11, 2019 4:42 am
by MLBS3V12
Maybe this is because the spring below is nt there:
#5 Re: Strange noise
Posted: Fri Dec 13, 2019 1:37 pm
by Ole-xke1974
Good call I
Certainly a possible reason I didn't think about.
That spring is there to prevent the SS shield from rattling.
